Clutch Basket Crossover
My clutch basket broke last weekend. I currently have a line on a used basket, but also want to look at all my options. Stock baskets are expensive and none in the US as far as I can tell.
Has anyone ever used a CR250 basket? I have heard rumors that they may work and was wondering if it was ture. Thnks, Ed
2004 GasGas DE250 |
I would also like to know,, my 97 gg has some time on it and the knotches are worn deep...
Steve 16 Beta 350rr 04 KTM 525 sx/exc gone 03 KTM 625 sxc-rehab unit-did its job and now gone 03 GG 250 ec-gone 97 GG 250 ec Gone |
off topic a little here, but does anyone know what other clutch plates (steels and fibres) will fit a 09 EC300R? Assume the R and std models have the same clutch
2007 Gas Gas EC300 2005 CRF450X 2006 WR290F Wandas Bike 2007 CRF280X Rebeccas Bike |
cr250 fibers will fit, but they are thicker than stock ones by at least .1 mm each.. i've not had a chance to get a set and mix and match and see if stack height is manageable..
thanks for that, apparantly the cr250 steels fit, have a set of them on the way so will post up when I know the answer
if you can make cr250 steels and fibers work together and end up with a manageable stack height, that would be awesome.
81 cr450 fibers are the same thickness, so are cb650 fibers
clutch basket mod | stainlesscycle | Enduro Engine - 2 stroke | 5 | 02-09-2010 10:12 AM |
Clutch Basket | jriley43 | Enduro Engine - 2 stroke | 2 | 03-10-2009 02:12 PM |
125 clutch basket | GasGas | Enduro Engine - 2 stroke | 1 | 09-08-2008 10:46 PM |
