Old 09-29-2015, 06:12 PM
12Bravo's Avatar
12Bravo 12Bravo is offline
Default How do they look?
The pictures are of the old reed and the new reed that came in the parts box.
How do they look?
Old 09-29-2015, 07:13 PM
Ones on the left are shot. Ones on the right look new
Sent from my iPad using Tapatalk
Old 09-29-2015, 07:30 PM
12Bravo's Avatar
I don't know anything about them. Short as in worn, need replaced?
I am cleaning the carb, figured I would take these out for inspection.
What are the recommendations? Will the short ones work while I learn a bit more then put the new ones in later, or are they shot.
Old 09-29-2015, 07:37 PM
They are shot. See how the corners are rounded and frayed? Where the ones on the left are nice and square
Old 09-29-2015, 07:39 PM
12Bravo's Avatar
This is all learning. I read some post and some google searches that had some that looked like mine and people said they still had life in them. So I just wanted to check here.
Old 09-29-2015, 08:34 PM
The ones on the left are two stage reeds the top peddle is smaller than the bottom so it may be an optical illusion. I would take them off an look at the edges and mating surface. If they have crack or if they are not smooth on the mating surfaces, you should replace them. If you are in a bind you might be able to flip them over so you have a new mating surface.
Old 09-29-2015, 08:56 PM
12Bravo's Avatar
I have the new set, but I might try flipping them and seeing how it works. Or I might just use the new set depending on how much they are to replace.
