Old 10-25-2020, 11:58 AM
Default 300 EC owners, what voltage do get from your alternator
What voltage do you get from your alternators on the 300 (model year 2018 and 2019) ?
On the 2018 GP I measured 13 v when idling then opened the throttle but only got 13.4 volts
My Kato delivered 14.5 volts.
Old 10-26-2020, 02:01 PM
SpirosZ1000's Avatar
SpirosZ1000 SpirosZ1000 is offline
Same here. With fully charged battery 13v to 13,2v at idle and 13,4 to 13,5v when revving it.
Gas Gas EC 300 2006
Gas Gas EC 300 R 2015
Gas Gas EC 250 GP 2018
Old 10-26-2020, 03:23 PM
Thank you! Seems to be a feature not a fault
Old 10-28-2020, 01:06 AM
I forgot to mention that I was seeing these numbers also on my 2015 model with a sido battery I had installed and to another 2018 model of customer of mine.
Gas Gas EC 300 2006
Old 10-28-2020, 04:59 AM
Spiros, it seems to be normal. Another colleague at Thumper Talk measured the charging voltage and the results are pretty much identical.
Funny that he measured 15.2 volts when he disconnected the battery....
Old 10-28-2020, 06:06 AM
The usual range for a charging system is between 13.5-15 volts. Due to the gassers single phase charging system they are slow to build voltage. Inherent feature unfortunately.
Old 10-28-2020, 07:50 AM
Thanks Nate, I see. That would be an explanation why we measured such a low voltage.
Alternator cover? motopsycho87 Enduro Engine - 2 stroke 1 03-27-2016 12:03 PM
WTB Alternator casing 450 FSE mikethebike1127 "Wanted to Buy" & "Want To Trade" 1 09-19-2015 05:55 AM
Need alternator help pscook Enduro Electrical & Wiring 2 03-17-2015 08:14 AM
GG300 wild alternator 2stroker Other GasGas Bikes/Quads 7 11-17-2010 10:40 AM
MC65 has a working alternator bergerhag Enduro Electrical & Wiring 2 10-09-2007 05:34 AM
