Old 04-17-2014, 11:46 AM
Toontje Toontje is offline
Default EC515FSR hard to start when cold
Hi all!
I have a 2009 EC515FSR which doesn't like to wake up in the morning. It takes at least a few minutes to get running, all the time starting it using the electrical starter.
I keep the air filter clean, i changed the spark plug from a NGK CR9EIX to the standard CR8E, but that doesn't make a difference.
Since this is a bike with injection there is AFAIK no "starter" position for the injection.
Any tips or tricks to make the bike start in the morning?
Thanks,
Ton.
Old 06-01-2014, 10:15 AM
Default Starting the 515 bearks the starter clutch
Hi all!
In one month i had to replace the starter clutch twice. I read on the forum that people have starting issues with the 450 and 515 mainly the '03 and '04 ones. Mine is '08 and i also have these issues.
Has anyone found a DECENT solution to this problem? Modifying the decompressor works?
I am desperate and put my 515 for sale again. If you look at how easy it is to kick a two-stroke. This is my fist 4-stroke and i think i made a mistake buying it.
Ton.
Old 06-02-2014, 05:34 AM
300ECR 300ECR is offline
Hi Ton a mate of mine has the 08 450 and was having the same sort of problem.
He had the program update and has fixed the problem 99% of the time. He has also found that some times he needs to open the throttle slightly. Hope this helps
Old 06-02-2014, 05:46 AM
What do you mean with this? Reprogramming the ECU unit? Can you elaborate on this so i know what to tell my mechanic?
Thanks,
Ton.
Old 06-02-2014, 05:50 AM
There is software update for the ECU. I think there is a link on Gas Gas Spain website. Most dealers should be able to help with this.
Old 06-02-2014, 05:51 AM
Where are you located?
Having hard time to start my trial bike ... nissan400 Other GasGas Bikes/Quads 3 11-08-2011 11:12 PM
Bike is hard to start when cold? blanc General Discussions & Announcements 2 07-02-2011 03:07 PM
Hard cold start rupecopp Enduro Engine - 2 stroke 8 11-30-2008 10:54 AM
Need help with cold start brains Enduro Intake/Carburetion - 2 stroke 12 01-11-2008 05:47 PM
'05 FSE won't start when its cold. AAARRRGGG! cobrad Enduro Engine 4 stroke (including EFI & Exhaust) 6 05-13-2007 08:37 AM
