Gotta make due with what you got... Maybe?
I've been wanting a headlight. Just a headlight, nothing else. Right now I got number plate. I went to my old junk pile and took a front light off my old 84 it200 Yamaha. I have no idea how to wire it and I have no diagrams. He's some pictures. Any commentary or help would be great. Needs a nice coat of black spray, bulb is good. I believe the high low switch is still on the 200. I got multiple toggles if need be. My ec250 I don't think ever had a battery. There's no room for one. So could I run it off the stator? I got the 2.2k. exits at 10 o'clock, smaller flywheel. Or the little black box coming off the coil. Believe it's the reticifier? Anyonewould be great. Electrical is not my strong suit... At all.....
This diagram may be of help; the alternator is a 2K-3. The AC output is the yellow lead that runs to a voltage regulator. You will need a regulator.
diagram: http://www.gasgasrider.org/gg-wiring.jpg regulator: https://www.rockymountainatvmc.com/p...tage-Regulator
'15 YAMAHA WR250F, '75 YAMAHA TY80 Gone: '00 380 EXC, '03 EC300, '07 YZ250, '07 250 XC-W, '08 YZ450F, '12 CRF250R |
Ahhhh ok I got you. Thanks a lot.
A really basic setup would be to have it on all the time the engine is running. Yellow wire off the stator connects to voltage regulator lead and whichever HI or LO filament you want to use. Other side of filament connects to ground. Done.
Or you could connect the filaments using a single pole double throw toggle switch. Yellow to the common switch terminal, other switch terminals go to the HI and LO filaments. The common side of both filaments is then grounded.
2011 EC250E |
So I will need a switch? I'll see how the it200 one is today. I got some videos last night using a test light. Yellow is indeed power. Here's a video. I don't have any switch hooked up yet. https://photos.app.goo.gl/LbefWxWbMAMjxysM7... I want to know what that wire Down near the expansion chamber is for. High/low switch? I just mocked up the airfilter so I could run some tests. This is a 2007 subframe on an 2005. I am waiting on my 07-09 plastics and airbox assembly.
You only need a switch if you want ON/OFF (basic SPST switch) using one headlight filament. If you want to change from LO to HI buy a SPDT switch (yellow connected to the common terminal). You could also buy a SPDT switch with a "center off" function if you want to turn the light off.
SPST=single pole single throw SPDT=single pole double throw center off means the switch has three positions Your link does not work (just goes to some login). Attach the picture to your post if you want people to see it.
2011 EC250E |
Not a Gasser, but you gotta see...... | desertgasser300 | Pictures & Videos | 3 | 12-27-2011 05:42 AM |
The Pro's Make It Look So Easy | Rick | Pictures & Videos | 1 | 12-04-2011 10:49 PM |
Gotta Love It | Rick | Pictures & Videos | 1 | 05-04-2010 05:59 AM |
Do they make FMF SST | gasser250sm | Enduro Engine - 2 stroke | 1 | 12-26-2008 10:16 AM |
If we make it... would you buy it? | Steve@Motowest | GasGas Member Polls | 12 | 07-09-2008 01:15 AM |
