Yep, another starter thread
Hi all,
I just installed a new starter on my 2018 ec300 that I purchased on ebay for around $100 AUD after my original starter stopped working. This is the one I bought https://www.ebay.com.au/itm/19479391...3ABFBMyIrrxKJg. To my surprise, the new starter does not seem to have enough muscle to kick the bike over. My old starter, before it seized had no issues with regard to having enough muscle to kick the bike over. When I bought the new one on ebay I noticed another brand that was more than double the price however I thought I would give the cheaper one a try. Here is the dearer one https://www.ebay.com.au/itm/31209183...ery!2280!AU!-1 Does anyone know if it would be likely the dearer one in the second link would be able to do the job better. They are both 410w however I am not sure anything else would be different between the two. thanks in advance. JC |
The KTM starter spins the opposite direction.
Did you rotate the starter housing? |
Yes I did do that. It engages correctly and tries to crank the bike over but it's just not strong enough.. Thoughts?
Is your battery good enough? Did you try another battery or jumper cables?
Check your battery and/or jump it like mentioned.
That said, I don't trust anything off ebay as it's a crap shoot whether you get what is actually advertised and if it's quality is decent or not. It might say it is 410w starter but who actually knows?
Yeah, I had already upgraded the battery to a higher CCA battery. I even attached some jumper leads to the car battery but no different. Perhaps I'm not really getting 410w as you say. Perhaps the dearer one would be better quality..
Remember ancient Chinese proverb: Cheap ting no good. Good ting no cheap.
Bahaha 👏👏👏
2018 Starter Fix Thread - Continued. | webmaster | Enduro Electrical & Wiring | 162 | 04-26-2023 02:57 AM |
My Go Pro HD Thread | SideshowBob | Pictures & Videos | 18 | 04-25-2011 03:07 PM |
thread | jriley43 | General Discussions & Announcements | 15 | 03-17-2010 03:51 PM |
test thread | HuskyDude | Suggestion Box | 0 | 01-30-2010 01:26 PM |
test thread | HuskyDude | Suggestion Box | 0 | 01-30-2010 01:10 PM |
