Old 10-03-2011, 11:15 AM
Neil E. Neil E. is offline
The axle seals work fine; stainless spacers are great and speedi sleeves are the next best thing. Just a short note about assembly. You need to be sure the axle is drawn over against the left fork leg. This pulls all the parts tight so the spacers stay fixed to the axle (stationary). If the axle is not drawn up fully, the spacers can creep and water will get past the faces that would normally be tight against each other.
Only lightly snug the left pinch bolts, then draw up the axle tight. Final tighten the left pinch bolts then center the right leg and do up it's pinch pinch bolts.
If the left pinch bolts are initially too tight, your axle nut could be tight, but not be drawing everything together.
2011 EC250E
Old 10-03-2011, 11:36 AM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
You have to be careful with this. Sometimes the forks will bind.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 10-03-2011, 12:54 PM
Centering the right leg is always last, there should be no issue with binding.
2011 EC250E
Old 10-03-2011, 06:54 PM
Banned
Originally Posted by Bailey28 View Post
X2 on the checkpoint products.I have the spacers and the brake pedal bushing. Great product!
Old 07-10-2012, 09:10 PM
jeffs2200 jeffs2200 is offline
Hate to wake up such an old thread but I was wondering if anyone had found another alternative for rear wheel spacers. The bad thing about the checkpoint spacers is you only get one rear spacer. This makes no sense when you need two to do the job. Is it best to just buy oem unless you can get alocal shop to make some?
Old 07-10-2012, 11:16 PM
GMP's Avatar
GMP GMP is offline
The one you don't get is steel OEM and lasts a long time.
Rear wheel spacers revisited. Ud_luz Enduro Chassis & Body 9 09-13-2010 08:01 PM
aftermarket wheel spacers randy Enduro Chassis & Body 4 08-20-2010 06:30 AM
Aftermarket wheel spacers. Wiggy Enduro Chassis & Body 1 04-01-2010 05:14 PM
no preload spacers jasont1532 Enduro Suspension 23 04-07-2009 02:48 PM
Machining Project Part 3: Stainless Wheel Spacers SpeedyManiac General Discussions & Announcements 1 03-23-2007 06:36 AM
