Old 09-25-2018, 06:06 AM
Wypipo Wypipo is offline
Default What size rear sprocket for XC 300
I?m looking to make my 18 XC 300 lug a little better. How much of a difference will a bigger rear sprocket make? Will it change the feel of the bike everywhere else? Size reccomendations?
Old 09-25-2018, 06:30 AM
Anders Anders is offline
Many uses 50t at the rear with good results.
Old 09-25-2018, 06:45 AM
Bigger gain needed with 50T ?
Old 09-25-2018, 07:24 AM
I think the chain will need another link to fit the 50T on.. maybe.
I've always ran 13-50 in my bikes. I find it just tightens up the ratios enough to keep it on song a bit easier and avoid having to knock back to 1st too often.
In saying that I'll be giving 13-48 a red hot go on my 18. If they make the extra powaaah they claim they do it should be aye OK.
Old 09-25-2018, 09:17 AM
Wimpy525 Wimpy525 is offline
I've been running 13/50 on my 13, will run the 13/48 that came stock on the 18 and make the decision when that wears out. I was pleased with the 13/48, if you go to a 50 you will for sure need a few more links.
Old 09-25-2018, 01:26 PM
I’ve run 13/48, 13/51 and 12/48 I prefer how the bike handles with the 12/48 wheel base on my 2010
Old 09-25-2018, 02:07 PM
GASGASCWB GASGASCWB is offline
Originally Posted by swazi_matt View Post
I?ve run 13/48, 13/51 and 12/48 I prefer how the bike handles with the 12/48 wheel base on my 2010
My GG 2018 comes with a 13/48.
Maybe 13/50 is better for hard trails...
Minor clutch use!
Old 09-25-2018, 03:45 PM
AZRickD AZRickD is offline
I?m going to stick with 13/48 for the time being.
Now that I have installed the Rekluse, I have even less reason to swap.
I don?t do a lot of super-duper tough climbs, though.
Old 09-26-2018, 01:29 AM
For single track I run 13/52. 13/50 works well for more open riding. 13/48 could cause more clutch wear if you ride slower terrain. You can always run a 12 counter sprocket with the 48 to get your ratio closer.
Old 09-26-2018, 11:07 AM
I had dropped my 2011 GG250 down to 12T to good effect.
Counter sprocket wear is increased a few percent. Not bad.
I don?t think I will go with the smaller CShaft on the 300.
Of course, I don?t have enough chain slack for a larger rear sprocket, so a new chain is factored in (I won?t just add links).
At some point the larger rear sprocket starts to interfere with the chain guide. A 50T seems manageable. But I had do modify my 2005 GG 250 chain guide (an XR400 guide) when I tried a 52T and was never quite satisfied with the fit.
WTB Rear Sprocket pscook "Wanted to Buy" & "Want To Trade" 2 03-02-2016 07:42 AM
Front sprocket circlip size? motopsycho87 Enduro Engine - 2 stroke 3 03-25-2015 12:13 PM
Front sprocket cir clip size thejackrabbit Enduro Engine - 2 stroke 1 04-01-2014 08:36 PM
Front sprocket size for EC400FSE Aircraftmech76 Enduro Engine 4 stroke (including EFI & Exhaust) 0 07-02-2012 06:10 PM
Sprocket size for 2011 6days 300? redrider Enduro Engine - 2 stroke 3 10-24-2011 02:58 PM
