The RickyD Lectron Experience
Let the futzing begin...
Whats the verdict?
I had some mountain bike repairs to do and V-ball practice so I finally got to it an hour ago.
The first problem is the "long" Motion Pro throttle cable. It is 4.5 inches shorter than my stock GG cable. Also, the GG cable has that nice curve at the carb junction whereas the Motion Pro is straight. |
Here is the condemning evidence...
Stock Gasser throttle cable is about 42.5 inches (when including the curve around the elbow). The new Motion Pro cable is about 37 inches. Last edited by AZRickD; 08-15-2013 at 01:14 AM. |
yep, I had the same experience. When I installed mine, I ended up using my spare Venhill cable wich is a tad longer than my OEM.
To be able to use the Keihin type cable, I made a new adjuster for the Domino throttle. My new adjuster lets the cable end go deep into the throttle housing instead of ending up outside the housing. This is nescessary as the Lectron has a longer reach from the top of the carb to the slide. The other option is, as has been discussed here previously, to cut off some of the outer shielding of the cable. I feel that my solution is a better one, as I can continue using stock cables and don't need to modify a cable every time I need a new one.
Just for giggles, I hooked the Lectron up to the Gasser's stock cable and throttle assembly.
Once the throttle pulley was screwed in, the slide was half way up. I don't feel like hacking up the GG cable. What is the proper length (and model number) for the Motion Pro cable I need? |
The correct one is about 3" longer
I could see that working, especially with the elbow bend.
The new elbow cable (and free adjuster nublet) arrived yesterday evening.
I was torn between getting the Lectron all fitted or taking advantage of the almost sub-100F evening temps for a mountainbike ride. We've been riding at 7pm every Wednesday with the temps still hovering close to 110F. I decided to pedal for 16-miles of trail and road. I'll get at it this evening. |
Alrighty. Having recovered from yesterday's 100-degree night mountain bike ride, I set to bolt the bike back together tonight.
Since I was promised a bolt-on, ready-to-go carb, I decided to *not* read the directions and just bolt it on and kick. I took the new elbowie throttle cable out of the package and found it to be really freakin' long. It came with a threaded cap nut thingy (invoice said it was custom for the GG) that was maybe 1mm longer than the one already in the Lectron. Not knowing why, I dutifully swapped them out. I hooked it all up with the the carb and threaded it through to the throttle. Perfect, much to my surprise. The Lectron's fuel inlet is at a different angle, so the fuel line wouldn't reach quite far enough for a secure clamping. So, I took the fuel line off my old GG tank and put it together (with double springs, even). A little long right now, but it would do for the evening's short test. Once together, I took the bike off the stand and turned on the petcock. The fuel filled the clear bowl and stopped between the level lines, as if by magic. As I rolled the bike off into the dark driveway it occurred to me that I had recently replaced my headlight with the Honda racing number plate. This would be an interesting ride by dim street light should the Lectron decide to let the Gasser fire up. I pulled the semi-remote choke knob and gave it a couple of pre-kicks (that's what I would do with the Keihin, anyway -- couldn't hurt). Then I kicked in earnest a couple times. Nada. I wondered what would happen if I cracked the throttle a bit? Vroom. Heh. It was running. I turned the idle screw in a quarter turn to keep it from stalling. I let it warm up for a scant minute and decided to roll before someone called the cops. Not much of a test, but off-idle was fine -- the metering rod, at 49mm, must be pretty close to where it is supposed to be. I putt-putted around the neighborhood with several throttle blips for giggles and then took it out to the main street to see how it ran on top. I ran it through the gears and noted some open-throttle sputter at WOT. With the second pass there was less. Kind of like when I was one main jet too rich in Flagstaff. Actually, not that bad. I'll work on adjusting the Power Jet later (like, maybe after I read the directions). I re-entered the neighborhood and into my garage. I hopped off the bike with the motor running happily and looked behind me. No smoke. Hmmmm. And with that, I hit the kill switch and headed inside. More tuning talk later. |
The Lectron - Review (vs SmartCarb) | Jakobi | Enduro Intake/Carburetion - 2 stroke | 234 | 01-28-2014 08:13 AM |
Smart Carb vs Lectron vs RB-Designs Mod | AZRickD | Enduro Intake/Carburetion - 2 stroke | 49 | 08-09-2013 12:18 AM |
Lectron Carb | singletracker | Enduro Product Reviews | 145 | 07-27-2013 12:20 AM |
Lectron Carburetor Testing & Adjustment | singletracker | Pictures & Videos | 4 | 01-12-2013 09:37 AM |
Lectron | Binni | Enduro Intake/Carburetion - 2 stroke | 16 | 03-29-2011 09:44 PM |
