Old 04-27-2016, 05:02 PM
Cox76y Cox76y is offline
Default Pfp adjuster
I'm just doing a bit of maintenance on my zokes and noticed that when I turn the pfp there is no click. Does anyone know how to fix this? Is it going to be a problem? I know I can count the turns.
Thanks
Jc
Old 04-27-2016, 05:14 PM
Anders Anders is offline
Thanks
Jc
There is no fix, as there is no problem. The pfp adjustment does not click in the fist place (at least does not my 15 model do so)
Old 04-27-2016, 06:06 PM
Correct! PFP simply runs up/down a fine thread and is limited in travel by a couple snap rings/circlips.
The actual clickers can be a bit faint if packed up with excessive grease. No issues there either though.
Old 04-27-2016, 09:26 PM
Ok,
That's good news. Whilst on the subject I'm changing my fork oil n want to put a little more in than I had last time. It's great 90% of the time but on some big erosion mounds bottoms out. Thinking I'll try a bit more preload and fork oil before I fork out the extra cash for new Springs. How much oil are people putting in the 48mm zokes?
Thanks jc
Old 04-28-2016, 07:35 AM
Reposted
Old 04-28-2016, 08:29 AM
5w, 325cc each leg.
PFP adjuster gasgasman Enduro Product Announcements 5 07-12-2015 06:10 PM
Home made PFP adjuster tool. gasgasman Enduro Suspension 5 04-04-2015 07:29 PM
Chain adjuster bolt questions liamthom Enduro Chassis & Body 8 12-18-2014 12:42 PM
Sachs shock compression adjuster? SpeedyManiac Enduro Suspension 2 03-26-2010 02:13 PM
Manual Cam chain adjuster MrSmooth Enduro Engine 4 stroke (including EFI & Exhaust) 16 12-25-2006 02:35 PM
