Old 03-09-2011, 05:04 AM
Muzungu Muzungu is offline
Angry EC200 Six Days gear shaft broken
Took receipt of my new EC200 over the weekend - changed from a previous 200 of an orange persuasion - running in is tedious but still a magic little machine even for someone over 100kg....until the gear selector broek off the end of the gear lever shaft that is. End of fun - after just 2 hours.
Anyone else experienced such a problem with this machine?
muz
Old 03-09-2011, 06:55 AM
kendunn kendunn is offline
muz
Wow, did it take a pretty good hit? If not I imagine it was a flaw in the casting and would be talking to my dealer.
2006 EC300, 2000 XR650R, 2003 EC250, 2001 EC200 (OK, the last two are really my sons).
Old 03-09-2011, 07:36 AM
Thats a first. Good news is its an easy fix, just the side cover and clutch need to be removed.
Old 03-09-2011, 03:13 PM
Nope - no hit - merely went to change down - and - nothing - just a floppy lever! Dealer has ripped it out and the weld between shaft and selector fork is almost non existent and was only welded over a length of about an eight of an inch - hence the failure.
Muz
Old 03-09-2011, 04:05 PM
Zeal Zeal is offline
I've never had a problem. I think if you slam them into a couple stumps it makes them stronger. Well, thats how I break mine in, and I never had a problem. Sounds like a 1 off.
Old 03-09-2011, 05:02 PM
Cruiser Cruiser is offline
Had one on an 03 250ec do this.. but it had about a year of use on it..had a buddy tig weld it,, stronger than new..
Steve
16 Beta 350rr
04 KTM 525 sx/exc gone
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 03-09-2011, 05:03 PM
And just a FYI.. I have a KTM 4stroker that has a similar issue right now..off again to the welder..
Steve
16 Beta 350rr
03 GG 250 ec-gone
97 GG 250 ec Gone
Old 03-09-2011, 07:46 PM
Keg Keg is offline
On my 07 I hit a rock really hard and broke the shaft at the weld too. Better than bending a shift fork in the gear box or something else more expensive.
Old 03-09-2011, 08:49 PM
I misunderstood, thought you snapped the end of the shaft off.
Gear shift shaft question (again) Trailrider Enduro Engine - 2 stroke 7 04-06-2010 09:54 AM
help and advice please 400 output shaft Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 0 11-01-2009 03:14 AM
Gear Selector Shaft Bent? iancp5 Enduro Engine - 2 stroke 11 03-29-2009 04:39 PM
pv actuator shaft broken help plz fullthrottle Enduro Engine - 2 stroke 0 07-26-2008 12:46 AM
Broken Kickstarter shaft JCW Enduro Engine - 2 stroke 8 12-07-2007 08:31 AM
