#11
Thanks for the offer jostby . But after what you said about the mount rubbing holes in the fuel tank . I think I would be better off designing one up that doesn't interfere. Or might even not run one at all if I can get away with it. Anyone have a issue with not running this mount?
I just ran out to look at my tank . There is a nice notch wore out were the bolt has been rubbing.
03 EC300 The pig...04 XR650L 01 380sx |
#12
The mount is not a problem if you use a short bolt, and will only touch if the pipe is bent. I had one that was close. I cut a strip of plastic, formed it in a "U" shape, drilled a hole in one side, and bolted it to the pipe mount so it wrapped around the back and protected the tank. Worked fine.
#13
I had to move (cut and reweld) the mount on my FMF pipe when my bike was new , to get it not to hit the tank.........
#14
Wouldn't happen to have a pic of that ?
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 | REVERUP | Enduro Product Reviews | 28 | 12-30-2013 09:05 PM |
06-07 GG OEM Pipe . Or . 07 Black Standard Pipe | gasser250sm | Enduro Engine - 2 stroke | 5 | 02-06-2009 01:07 PM |
Exhaust Clearance at rear pipe mount | REVERUP | Enduro Engine - 2 stroke | 12 | 01-15-2007 05:43 PM |
