Bushing engine mount due to worn mounts
Hi.
- Aluminium top mounts was broken when I bought it, replaced it, but rear engine mount was quite badly worn out. This also includes damage/wear on the side of the mount, so i am wondering about measurments on the engine block. As stated in picture, the measurment from A, to B at the rear engine mount. - Bolt is 17mm - My left hole is 19,5mm wide, 18mm high. - Right hole is 18mm x ca 18mm. Questions: - Tolerances bolt against engine mount hole? 0,4-0,6mm? - Measurment from hole to outer other casting? So i know where center is. What does other people do with this?
07` EC300SM. 09` KTM 250EXC. 70`CB350 Last edited by stian; 03-14-2015 at 06:54 AM. |
Broken Engine mounts: 2011 EC300 :( | fenwickwick | Enduro Engine - 2 stroke | 17 | 02-25-2015 10:36 AM |
engine mounts on ec 300 2013 | mikhogl | Enduro Chassis & Body | 2 | 04-25-2014 10:38 AM |
EC200 Engine Mounts | Jakobi | Enduro Chassis & Body | 3 | 10-24-2012 05:56 PM |
Engine mounts on to frame | west aussie gas 450 | Australia & New Zealand | 3 | 01-28-2007 08:16 PM |
engine mounts on to frame | west aussie gas 450 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 10-26-2006 08:59 AM |
