Old 05-02-2015, 06:33 PM
chaddlez chaddlez is offline
Default unknown wire coming from ECU>????
Hi Guys,
ive got a 02 400FSE which looks to be upgraded to a 450FSE .
Anyway when i removed my battery i found a wire that looks to be Blue and Green striped i followed this wire back to the ECU i runs from the main harness that plugs into the ECU ive tried to find a wiring diagram to explain what im looking at as u can see its been connected previously but dont think its an earth as there is already an earth wire running from the ECU plug
ive added a few photos.
Any help would be greatly appreciated
Cheers Guys,
Old 05-03-2015, 12:53 AM
(F5) (F5) is online now
That'd be the traction control, its connected to ground through a 10k resistor or via a switch so it can be turned off if desired. It was deleted on later models due to the cost of the resistor.
I'm a bad bad person
Old 05-03-2015, 06:07 AM
[QUOTE=(F5);152098]That'd be the traction control, its connected to ground through a 10k resistor or via a switch so it can be turned off if desired. It was deleted on later models due to the cost of the resistor.
Thanks for that mate,
would it be ok to leave it disconnected, also do u know of a wiring diagram that is abit more descriptive than the one in the standard manual
Old 05-03-2015, 02:30 PM
Sorry man, I have absolutely no experience with the 4 stroke setups. I was just feeling mischievous. Thank you spell correct.
Old 05-03-2015, 02:41 PM
Ha ha no worries thanks anyway
2014 EC250R broken head :( Cause Unknown blamir Enduro Engine - 2 stroke 19 12-14-2014 12:42 PM
Hot Wire Smell ?? StuJohnson Enduro Electrical & Wiring 2 06-16-2013 10:33 AM
white wire bonkeye Enduro Electrical & Wiring 3 04-29-2013 11:54 AM
Help. Little black wire Hicksi Enduro Electrical & Wiring 12 08-19-2011 02:11 PM
No Yel/Blu wire effect. cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 8 01-12-2009 10:29 AM
