#11
Mine takes an external 9v battery. I got the battery holder and connector fron Radio Shack.
Let me know if you can't find the manual. I think I have a PDF version.
06 Kawasaki KLR 650, 21 Beta 300 RR |
#12
You can store read only data with flash memory (example: NAND or NOR logic gate) but to have an active function like a clock, you have to have a power supply of some type.
-Mike 2009 Beta Evo 300 4T - 1982 Suzuki PE175 |
#13
But it seems only GasGas could fit a set of clocks on which some of the features never worked right from the factory
Regards Shuv - 2006 EC 250 |
#14
Exactly .
#15
Are all Gas Gas Speedo rubbish?? I've a 2003 EC300 and the clocks never worked in the time I had it. Lately I've decided that I want to use it on the road and have fixed all the lights and was wondering about the speedo.
Can they be fixed, or should I just go for an after market set, something like in the link below. Are there any of the after market sets better than others. What do you guys recommend... http://www.ebay.co.uk/itm/Trail-Tech...item33953be616 |
#16
Can't go wrong with anything from trail tech. I have the voyager gps and it works great.
#17
I finally go around to buying a speedo for the bike and ended up with a Trail Tech Vapor, however the instructions talks about connecting it to a 12 volt supply but as my bike (2003 EC300) doesn't have a battery where should I connect it to??
Plus, I bought the device of ebay and it didn't have have any of the cables with it, so any advice on where to get the cable I need?? As far as I know I need one for the temp, one for the rev counter and obviously one for the speed and a magnet for the brake disc... |
#18
Trials bike and enduro parts? | lankydoug | General Discussions & Announcements | 19 | 03-16-2012 03:39 PM |
instrument cluster/multifunction | vwboomer | Enduro Electrical & Wiring | 4 | 06-19-2010 09:08 PM |
Anyone take their enduro bike to a trials ground? | stay_upright | Riding Techniques & Training | 0 | 12-11-2008 07:50 AM |
Can the Enduro use the trials bikes FR sprockets? | cal_tony | Enduro Chassis & Body | 2 | 11-24-2008 09:48 AM |
