2013 rad leak
Really not having any luck with my bike right now. Does anybody know which other years or models may fit a 2013 ec left hand side rad
Where is the leak? Might be able to get a competent welder to tig it.
Have a bit of a search but in my recent googlings all EC models from a span of about 15 years all fit each other
I have managed to find one from an 02 model on eBay but have no idea if it is going to fit and can?t seem to find a definitive answer anywhere online! |
This is a screen shot from the video as I can?t upload the video to the site not sure how good it is or clear
Where are you located? There may be someone breaking a bike in your country. I could send you one from a 07, but postage will be very expensive
Where are you located? I have a set of Radiators for a 13 EC300 with BRP guards, a bit twisted but don't leak. 200 for the pair with the BRP guards.
Checking the parts listings on here: https://www.motocrosscenter.com/shop...diators-grills
Looks like 2000-2005 are the same as each other. 2006 is an odd one out. Then 2007-2017 are another design. If I were you I'd be buying the China ones off eBay if you can't find a decent used pair. Have read about several people using them and they said they are fine. |
I've had the cheap ones off Ebay and there
fine. If anything , more robust than OEM |
+1. I have a set on my '05 300 and they work great.
Coolant leak | welsh.Z.S. | Enduro Engine - 2 stroke | 10 | 03-27-2017 12:29 PM |
Radiator leak | Buysomerice | Enduro Engine - 2 stroke | 10 | 10-06-2014 09:34 PM |
Weird one - oil leak | blitz11 | Enduro Engine - 2 stroke | 2 | 09-25-2012 12:12 PM |
Leak leak leak... | AnthGG | Enduro Engine - 2 stroke | 4 | 12-15-2011 08:10 PM |
Gas cap leak? | colinmc400 | Enduro Chassis & Body | 6 | 05-21-2007 07:09 AM |
