Old 08-31-2011, 07:41 PM
jimjim jimjim is offline
Default cracked case
My 03 300 had developed a ticking noise somewhere in the engine that I could hear at idle,turns out I found a small crack (about 1 inch) at the top of the reed housing.I wonder how this happened?I guess I can put some JB weld on it and call it good?Any other suggestions?Thanks.
Old 08-31-2011, 08:05 PM
einsteingarage einsteingarage is offline
JB weld should do it. I used it on a clutch cover hole for years.
Old 09-01-2011, 01:01 AM
Adrian Adrian is offline
Sounds like where the cases go together and the gasket is gone in that area. If so and if were mine I would replace the center case gasket.
Old 09-01-2011, 07:34 AM
You are right,there is gasket material sticking out,there appears to be no seam there,I will look closer today and get a pic.Thanks.
Tank cracked at mounting point Bailey28 Enduro Chassis & Body 8 05-15-2013 01:47 AM
Seat has cracked at the back - is this common? stay_upright Enduro Chassis & Body 6 07-23-2012 06:53 PM
LTR case saver thespice Enduro Engine - 2 stroke 4 01-15-2011 08:51 PM
Case hole? Neil E. Enduro Engine - 2 stroke 4 11-29-2010 10:16 AM
Messico Pipe cracked! pbspecial Enduro Engine - 2 stroke 13 01-07-2009 09:28 AM
