Old 08-11-2009, 06:51 AM
GMP's Avatar
GMP GMP is offline
The small Kokusan MX ignition stator with no lighting coil is actually a 2K-1. I thought some MCs came with this.
Also, the KTM Kokusan 2K-2 uses the same stator as a GG Kokusan 2K-2, I verified this myself on my friends '00 300 EXC, even the plates are similar(for the '00 motor). So the same mod as Matt linked to could apply to adding lighting to an MC250 with a 2K-1, or to replace a bad 2K-2 stator.
Old 08-11-2009, 07:30 AM
SideshowBob SideshowBob is offline
Originally Posted by MattR View Post
Josh,
Can you take a pic with the flywheel removed? It would be good to see if there is a lighting coil on your 2k-2.
Here is an example of the 2k-2 without lighting coil. Note: this is a Husky CR125 but it will show you the differences.
http://www.cafehusky.com/forums/showthread.php?t=3067
I happen to have one!
Edit- looking at the cafe husky thread it looks like I need to remove the flywheel wieght and the stator cover to get a look at what you guys are talking about?
2003 EC250 w/ Ohlins pkg
Sometimes you eat the bear, sometimes the bear eats you.
cool things found in the woods.. stainlesscycle Ride Reports 28 02-15-2011 11:29 PM
Getting lighting back on my 2003 EC250 SideshowBob Enduro Electrical & Wiring 16 03-19-2010 05:52 AM
