#231
Am I missing something here?? I had my old one off and the all new components installed and back together in an hour...... Steve - These subframes are for GG bikes not Beta's.....
2012 - XC 300 Racing Seattle, WA |
#232
Initially the installed seat didn't fit, so some ribs were removed there. After the seat fit it was time to create a loop to hold it at the rear of the tank. Then I had to chase down fasteners etc, etc. Great directions though
#233
Steven -- how was the mud fest yesterday? See you took first nice job.
What are we talking about here the new Alu sub frames? |
#234
Nevertheless I scored my first 3 hr overall points on the year, so there's that. PM me or call and we can discuss at length. I fitted the 2013 alloy subframe to the 2012 I have for sale, and sold three others as well.
#235
I put my 13 subframe on last night , but can't seem to get the 12 tank to go back in , my petcock seems to be catching on the cylinder , it was getting late so I only had a quick go , I know moddett says he used the 12 tank so it must be possible , has anybody else come across the same issue and solved it .
I also ordered the electric start subframe fit and the battery box does not come with it :-( . Any help would be much appreciated Chris |
#236
I too had issues fitting the tank, but it will fit. a little force may be required. and a tether for the seat base since the battery is attached to the seat base.
#237
Your not wrong there
#238
Yes the 12 tank is in with a lot of squeezing , the petcock catches on the cylinder on the way down , you can pull it away enough to give the top of the tank a bang , she then goes in .
Next problem is getting the bolt in at the front of the tank , I thought it was bad before , now it's half an inch out , it's in now though . Now to hack the battery box up |
#239
Pic of it on
#240
I did a bodge job on the box and it's not turned out so bad , considering I'm away from home and only have a handfull of tools
Link to WEC Heinola Finland Frame by Frame | REVERUP | Pictures & Videos | 0 | 09-16-2012 09:31 PM |
2002 frame; same as a 2005 frame, or close enough? | Trooper Sam | Enduro Chassis & Body | 0 | 06-10-2010 09:18 AM |
