Old 05-17-2013, 03:09 PM
Earwinder Earwinder is offline
Default 2013 EC 250 carb/jetting
Hi
I have a new 2013 EC 250
Came with a Air striker 1 and not AS 2(as per manual!)
Anybody have got the same combo bike and Carb????
Jetting suggestions will be greatly appreciated
Elevation: 1450 meters to 1550 metres
Temp: 10-25 deg cent
Thanks!!!!!
Old 05-18-2013, 03:27 AM
Follow up questions:
Are there quality differences between the AS1(screw cap) and AS2 (flat bolt on) carburetors?
I know the bowl volume and float level differs but it is still 38mm diameter for both carbs
Will the AS1 work better in the 250 than the AS2?
Like in fuel efficiency, engine resonse, etc....
The throttle cable seems more 'cramped' under the fuel tank in the AS1 (screw cap)
The manual's jetting recommendations are for the AS2, so I'm lost if there are separate jetting/needle recommendations for the AS1.
Thanks guys
Old 05-18-2013, 04:39 AM
gasmonkey's Avatar
gasmonkey gasmonkey is offline
Bronze Level Site Supporter
I don't think theres much difference between them.The as2 is a later model is all.They do jet differently though.
Don't bother with the manual.The standard jetting is crap.
GMP you can chime in here.
Check out the jetting stickies thread.
Old 05-18-2013, 06:38 AM
GMP's Avatar
GMP GMP is online now
The ASII is a shorter body carb with a stronger signal for theoretically better response. In reality, from all accounts here over the last few years, it seems like more of a PIA to get right. The ASI on a 250 is absolutely fine, I'm fact I prefer it. It also fits better in the airboot. It just wants richer jetting specs, fuel economy is excellent on my 250s. The other nice thing is its a lot easier to get the top off for a needle change, but once your set its a pretty stable setup, I only turn the airscrew and swap the pilot seasonally. 250s are also less fussy than 300s anyway, plus you use more of the range and use it faster so any small jetting inaccuracies are not as noticeable as on a 300.
Old 05-20-2013, 04:35 AM
So suggestions for an AS1 would be around an F/G diameter needle. NECx/NEDx (suzuki needles) or N3Ex/N3Cx (Yamaha and KTM needles), or a JD Blue.
2013 gg 125 gasgasman General Discussions & Announcements 32 10-25-2012 06:25 PM
2013 300 ES = Amazing hasslbri Ride Reports 9 10-18-2012 12:22 PM
Slide Theory, Carb Models, and Jetting Jakobi Enduro Intake/Carburetion - 2 stroke 37 10-15-2012 08:53 PM
Jetting: 2011 250 (38mm carb ASII) Jakobi Enduro Intake/Carburetion - 2 stroke 53 07-23-2012 06:31 PM
New 2013 coming(?) Keep my old RB-modded carb? AZRickD Enduro Intake/Carburetion - 2 stroke 3 06-28-2012 09:47 AM
