Old 06-07-2019, 05:12 AM
andrius7 andrius7 is offline
Default Slipping cluch
Hi all, just fitted new set on my fse, after a half hour of riding it startas to slip on 4,5,6 gears
Old 06-07-2019, 05:17 AM
Anders Anders is offline
Did you check the spring lengths? Perhaps they are worn?
Old 06-07-2019, 05:57 AM
arminhammer arminhammer is offline
Too much fluid in the res.
Old 06-07-2019, 08:40 AM
Į left old springs, new ones are too long, but į might be wrong
Old 06-08-2019, 02:00 AM
Were they genuine plates? Did you measure the thickness of them? Did you pre soak them in oil before fitting as well?
Old 06-08-2019, 08:15 AM
OK, problem solved, just tighten 3 springs
Kickstart slipping. GGRider01 Enduro Engine - 2 stroke 11 01-27-2016 01:46 PM
DOT5 brake fluid in AJP cluch MC alecsstefan Enduro Engine - 2 stroke 12 05-25-2010 01:30 AM
Slipping kickstarter Warwick Simpson Enduro Engine - 2 stroke 10 07-11-2008 03:26 PM
Slipping clutch nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 12 06-18-2008 08:14 AM
