Welome! Fun to see someond building an electric bike. I woul like to heat more about your conversion.
When it comes to front suspensjon, there are a number of things you could try: Lighter oil (right now I run GRO 2.5 in mine) Less oil (I usually use about 250cc) A lighter PFP spring (I use the lightest one from racetech) And of course a rebuilt shim stack, ideally it should be built for your personal speed, track type and ability. If you ned more details, please ask. We are a number of people here that has some experience with the 48pfp forks Anders Sent fra min YAL-L21 via Tapatalk
2014 gas electric start parts | jarret440 | Parts | 0 | 07-11-2019 05:33 PM |
2014 ec300r suspension setup for 230lbser | Joehunt | Enduro Suspension | 8 | 04-27-2019 11:20 PM |
Radiator hose prob? | wence | Enduro Other... | 7 | 01-10-2015 08:32 PM |
clutch prob | flyinwalrus | Enduro Engine - 2 stroke | 5 | 06-17-2010 06:29 PM |
02 400 fse running prob | dan j | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 08-14-2008 05:44 AM |
