Old 04-24-2011, 10:11 AM
Thumbs up
I do the same thing, good plan. Also, there is a scotchbrite hone available from Mcmaster, that works great in a 250/300 cyl.
Old 04-29-2011, 03:55 PM
stay_upright's Avatar
Originally Posted by hannesd View Post
don't just guess what size of piston you're about to use!
measure with a 3-point caliper as stay-upright says!
only then can you determine what size of piston the cilinder needs...
i allso wouldn't go back a size from B to A, the scoring may have been from lack of lubrication one time or over heating.
stick with the same size or hone the sleeve lightly out and fit the larger size if needed.
hannes.
That's what I did the previous owner had put a B in it assuming the cylinder would have worn but I put an A in it as that was correct for the size of the cylinder. In fact even with an A piston I was still slightly shy of the clearance recommended by GG - but that's how they made the cylinder. I'm happier having the correct piston, it's simply going to reduce the chances of cold seizure, partial seizure and/or picking up on the piston/walls.
My advice would be put the piston in, as marked on the barrel in the bike unless you have accurate measurements to back up the fact you need a larger piston. The cylinders simply don't seem to wear. and IMO every one-else is simply guessing and cold or partial seizures seem to happen quite a lot.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
Old 04-29-2011, 04:53 PM
Banned
I cannot find a stamp on mine anywhere on the cylinder. Was it different for 97's
Old 04-29-2011, 08:05 PM
jostby jostby is offline
I think they were made by TM at that time(?).
'00 XC250 (mine)
'04 EC250 (the kids)
Old 04-29-2011, 10:15 PM
tm_enduro's Avatar
tm_enduro tm_enduro is offline
TM engines are marked too, although my '98 TM was market with ink. BTW, the '97 GG was a GG motor, not TM.
Hbg 496 wec
Polaris Dragon 800 163
How to go faster, no matter who you are. roostafish Riding Techniques & Training 22 07-22-2012 07:21 PM
Base valve pistons Marzocchi Shiver 45 Klausen Enduro Suspension 4 03-30-2010 06:05 AM
Euro Spec vs. USA Spec EC's - What's the diff? bondo General Discussions & Announcements 4 12-14-2007 12:12 PM
Compression distance difference on pistons Adrian Enduro Engine - 2 stroke 6 05-17-2007 06:50 PM
Any '07 US spec (DE) bikes yet? GMP General Discussions & Announcements 5 02-09-2007 09:10 PM
