#11
Steven |
#12
Bleed the clutch it fix
#13
To properly check the clutch lever free play, you will need to remove the master cylinder reservoir cap. When you pull the lever in oil should spurt up. If not, back the adjuster screw out until it does. |
#14
A stab at the lever and mine shoots oil across the room with the cap off. I've backed my adjuster all the way out and same thing: Cold it's good, disengages completely an inch off the bar- warm it up and the disengagement point moves to the bar.
Bled it thoroughly before I had to head out to Calif for a week on biz. I'm back and plan to start messing with this again. I'm taking the master cylinder apart in the next day or two and have a looky. Heard about the same problem on one that had machining bits left in there that scored up the cylinder. It's a long shot, but I have no idea what else to try at this point.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
Thread Tools | |
Display Modes | |
Friction plate part# ?? | gasIdaho | Enduro Engine - 2 stroke | 5 | 06-16-2013 08:03 AM |
What is the point of the bolt on the side of the head? | Motarded1 | Enduro Engine 4 stroke (including EFI & Exhaust) | 1 | 02-03-2009 06:17 PM |
