Old 04-26-2011, 08:46 PM
GMP's Avatar
GMP GMP is offline
12oz on a 2K-3? Thats a lot of weight. Likely it sheared from coming loose, I'd loctite it this time.
Old 04-27-2011, 02:33 AM
stay_upright's Avatar
stay_upright stay_upright is offline
2k3 I think - it's the heavier/more powerful euro ignition.
I'll have a think what to do when I re-assemble but I'm a bit wary of locktiting the weight and nut on as there's no tool to remove the weight you have to grip the outside with and turn - this time I made a 'tool' of some rubber and 2 jubile clips to remove the weight I could hammer the jubilee clip screw portion and this was enough to remove the weight - if it's too tight I don't know how you would get it off and applying heat may damage the crank seal.
What I'm thinking is I'll put the ignition on and get that as tight as posssible as the friction between the crank and the cover will help to stop it spinning - i'll de-grease the shaft first. Then put the FWW and nut on and probably just tight maybe some locktite.
When I first installed the weight I had no problems for 3 years only now since the rebuild (which I didn't do) have I got this problem.
'05 Gas Gas 300
'97 Aprilia Pegaso 650
'99 KTM 200
'95 ish XR630 (died many times in Oz)
Old 04-28-2011, 01:27 PM
Didn't manage to get it rebuilt in time for Wed practice but it's nearly together now.
Gave it a quick test and it fired up first kick, wasn't even a proper kick just a half hearted effort.
Let it warm up a bit stopped it and restarted it , again 1st kick with little effort.
Hopefully will be out on it on Bank Holiday Monday.
'05 Gas Gas 300
'99 KTM 200
'11 E-start bike batteries compmoto Enduro Electrical & Wiring 10 01-05-2011 02:57 PM
need a new air filter any suggestions.... dareuk Enduro Product Reviews 4 03-24-2010 03:05 PM
First enduro ever...tips/suggestions? sled_fiend Off Road Racer's Corner 8 07-10-2009 08:55 AM
EC Chain/Sprocket Suggestions? cdn280 General Discussions & Announcements 10 07-31-2008 02:22 PM
New DP clutch plates won't fit - suggestions? stay_upright Enduro Engine - 2 stroke 6 05-26-2008 09:59 AM
