#11
Probably carbon build up on the rod. You can take another rod that is slghlty smaller and push it through.
The engine side cover has to be removed to reset the governer actuator. |
#12
Second attempt. knocked out the left hand side double bearings and valve first by putting a rubber coated handle up through the exhaust port and using a little brute force. Then knocked out the right side bushing, bearing and right valve by passing the rubber handle end of a screw driver through from the left hand side. now time to clean and re assemble.
This side is a great source of information. |
LTR Power valve cover | skid jackson | Enduro Product Reviews | 22 | 09-04-2017 02:42 PM |
Power Valve Spacer | Dingo | Enduro Intake/Carburetion - 2 stroke | 16 | 01-22-2009 01:53 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
Sticky power valve?? | moff747 | Enduro Engine - 2 stroke | 9 | 12-22-2007 07:59 AM |
Power Valve rebuild | Gas Stu | Enduro Engine - 2 stroke | 2 | 09-19-2007 12:38 AM |
