Is it worth putting grease nipples on linkage?
Hi, my 250ec rear suspension linkage and swinging arm bearings require replacing now, so i have been thinking about fitting grease nipples on the bearings do you think its a good idea or im I just wasting my time?
I ride the bike quite a lot and always wash it after every ride which is not good on the bearings. I like the idea of pumping new grease after a few rides. I would rather spend the time riding the bike than stripping linkage down every month |
Synergy Seals (member here) is making bushings that replace the bearings on the Gasser linkage. Not sure if he makes zerk fitted bolts for Gasser. He does for the KTM PDS heim bushings, and the combo enjoys a great reputation. I have one on my KTM 300.
EDIT: here is a link- http://www.synergyseals.com/ His website states that he sells the bushings for the GG linkage, but his "store" doesn't have a link to purchase the kit. Looks like you'll have to call or e-mail him.
Newest Spanish Girlfriend: 2011 300 Six Days My Daughter is a U.S. Marine |
thanks I will send him a pm
I had grease zerks on my RMX.
They gave a "false sense of security". I would grease them often, then found out the grease in there was hard as a rock. Ended up having to replace them all. |
Don't do this. The GG system, with OEM bearings PROPERLY greased, and sealed with the orings is the best in the business. The bearings are cageless needle bearings, and so are more difficult to pack completely. They are not correctly packed from the factory. Solvent cleaned, dried, and repacked with proper grease the system will stay clean and tight all year as long as you keep the pressure washer away. Even then its more resiliant but I choose not to use a PW on my bikes. My bikes see mud every ride and a bath after, never a problem. I used to tear the linkage down a few times a season and never found any water intrusion, so I started extending service intervals and now just do it every winter. If your results are less you are doing something wrong.
After owning a Husky which came factory with Zerk fittings, I began installing them on everything, including steering head. It seems like a good idea, but the bearings do not last any longer in my experience. The steering head idea just pumped a pound of grease into the cavity and did no good. That was nothing short of not thinking on my part (was many moons ago). The one area where I thought it really helped was the swingarm pivot.
Mike Sheetz OMRA #21AA What will I be riding next? Christini GG 300? '15 KTM 300 XC-W '08 EC 250 (Gone to new happy owner) Gran Prix Cycle LTR Suspension RB-Designs |
I use a pressure washer religiously on my bikes and still never have an issue with the linkage. Grease every fall and maybe in the middle of the season. My last GG needed 1 bushing and bearing for the lower shock mount on the link after 5 years of hard use and pressure washing.
2018 EC 300 |
I replaced the 7mm wide seals on the '12 with two of the same 3.5mm orings. Much tighter and fits perfect.
White grease in 2011 GG linkage? | matt_tidball | Enduro Suspension | 10 | 01-21-2011 04:57 PM |
Putting in new rings | 101racing | Enduro Engine - 2 stroke | 16 | 04-22-2009 01:21 AM |
Spokes/nipples | Hapnin | Enduro Chassis & Body | 4 | 07-13-2008 07:14 PM |
