Old 06-12-2014, 06:12 PM
CampX CampX is offline
Default Clutch questions. '05 EC300
Been in the saddle of my '05 EC300 a lot more this year, and am loving it. I started riding with a couple of buddies (both are riding 2013 KTM 300s), and they are pushing me real hard, and I am definitely improving fast. (Just bought the EC300 last year, my 1st dirtbike I've ever owned, at the age of 41). They have been riding, and racing, for a long time, and the rides we have been doing are 3-4 hours of tight single track, lots of logs to cross, roots, rocks, creek crossings, and seriously steep hills. Lots of catch-up rests for them; I am whipped by the end, what a workout!
Maybe its me improving, or not knowing any better cuz this is the only dirtbike Ive ever had, but the clutch is super annoying. Gotta pull it all the way to the grip to fully engage, and I've got a 1/2-1 inch only, from the bar, til it starts grabbing. If you aren't on the gas by then, stall. Funny thing though, you can feather the clutch at about 1/2 pull to get the revs up. Tried bleeding it, tried the adjuster on the 'plunger', but still feels the same.
Any ideas? I read in here about how sweet the Gas Gas clutch is......how IS it supposed to feel?
Thanks!
Old 06-12-2014, 09:05 PM
celler celler is offline
It is not normal. Sounds like you have air in the system.
Old 06-12-2014, 09:46 PM
Okay. Did some searches on the ole 'net, and found out a few things. Backed out the setscrew adjuster on the plunger, bled the system more, added more fresh brake fluid, bled again. Definitely feels more 'positive' now.
Old 06-13-2014, 12:47 AM
I hope this isn't an AJP master which requires mineral oil.
Old 06-13-2014, 01:05 AM
Umm, it is an AJP master, but it says to use DOT4 brake fluid on it....whats the story?
Old 06-13-2014, 02:41 AM
noobi's Avatar
noobi noobi is offline
Dont worry. Ajp made clutch masters that used one or the other at various times. So long as you follow what's on the cap, you'll be fine.
Sometimes people assume the master cylinder runs one or the other without checking, which would be what Jakobi was referring too.
Sent from my HTC One using Tapatalk
Old 06-13-2014, 03:37 AM
Spot on noobi
Old 06-13-2014, 01:15 PM
Phew, thanks guys! Had me worried for a sec. Gonna take her for a rip and see what kind of change it made. That, and the compression adjustment to the forks that I just learned about.....wondered why I was feeling pounded by the front suspension, the compression clickers were 4 clicks from max!
Old 06-13-2014, 02:43 PM
Just got back from a little ride. Clutch is still the same, as in needs to be pulled to the bar in order to work. No leaks anywhere, no air coming out when bled. Maybe try the backwards bleed next....oh ya, I'm using Rotella 15-40 in the tranny, never had a problem before with it.
Old 06-13-2014, 03:13 PM
Banned
Just toss a Rekluse in there and forget about it. (swatting bees and stirring the pot)
clutch questions onekawboy Enduro Engine - 2 stroke 13 12-13-2013 05:56 PM
(2) questions about my '06 EC300: brider Enduro Chassis & Body 2 03-28-2013 09:23 PM
EC300 vs 250f questions forgiven General Discussions & Announcements 18 01-19-2012 08:08 PM
Questions - carb and clutch brains Enduro Engine - 2 stroke 3 07-23-2008 09:18 AM
