Old 07-31-2015, 03:12 PM
krazy's Avatar
krazy krazy is offline
Default N3EG - 1/8 stumble and lean 1/2 throttle
Hi,
I'm getting a slight rich condition at 1/8 throttle (but not too bad) and I've just done a plug chop at 1/2 throttle on a nice long 3/8 mile hill, see photo.
AS 1
40 pilot
N3EG top clip (leanest)
175 main
Motul 800 32:1
0-500ft 20c
The plug is light grey colour, definitely not tan or chocolate brown like we aim for. Is that too lean? I'm hesistant to do a WOT chop unless the 175 would be enough to richen it back up.
I can live with a slight richness at 1/8 throttle but I don't know about correcting a lean 1/2 throttle by using a richer needle and then having too much stumble at 1/8. So in my mind I am thinking a needle with richer diameter (leaner) but coming onto the taper sooner (lower clip pos) to fatten up the mid. Does that make sense or is it possible with N3xx needles? I thought they all had the same taper so all were about the same at half throttle.
Bike is powerful, 3rd gear power wheelies with 46t rear sprocket, no pinging.
2001 EC300, mild porting and head work, DEP silencer, EC200 CDI
Old 07-31-2015, 03:33 PM
Leaner diameter needle.
Richer clip position.
Richer main jet.
Leaner diameter may require a richer pilot jet to maintain the idle mixture.
N3EH/N3CH/N3EW/N3CW
Old 07-31-2015, 04:08 PM
krazy's Avatar
Richer main jet.
N3EH/N3CH/N3EW/N3CW
Great, will order some brass now and report back. Many Thanks.
Old 08-05-2015, 04:16 PM
krazy's Avatar
small update ... while waiting for n3ew and 185 main I put the cck back in on 3rd clip with 182 main. Real rich until 1/4 throttle as expected. WOT plug chop is a light tan, a bit too light. I am concerned that the rich cck needle and 182 main is on the lean side. No one else seems to go that rich. Perhaps I can't even use a N3 needle unless I go to 190 main or something. Either I have a leak or the head and porting work is better than expected and flowing more than others.
Old 08-05-2015, 08:58 PM
I have been chasing jetting for months. I ended with 40p 180m and N3CH clip 3. It is pretty good across the board. Nice and crisp. It will still lean out a bit on a long uphill but it's not bad any richer and it gets blubbery.
Sent from my iPad using Tapatalk
Old 08-06-2015, 03:20 PM
krazy's Avatar
Originally Posted by memphis2857 View Post
I have been chasing jetting for months. I ended with 40p 182m and N3CH clip 3. It is pretty good across the board. Nice and crisp. It will still lean out a bit on a long uphill but it's not bad any richer and it gets blubbery.
That's a point, I have been doing plug chops on a long hill, going 70+ by the time I shut her down. I suppose that gives it a lot of time to lean out, and not representative of a typical ride.
Your conversation with Jakobi a few months ago helped me decide to try the N3 needles so thanks for that. Hopefully the 185 main will be enough to keep things safe. Fingers crossed.
Old 08-06-2015, 08:35 PM
I tried doing plug chops and just never had any luck jetting that way. It's not "real world" riding conditions. If you really want to read your plug I think the most effective way to do it is after a typical days ride. That will give you an idea of how the bike is running as a whole. Just jet the bike where it runs good and doesn't bog or burble and then just go out and ride and enjoy life. I have friends that are so obsessed with jetting that they put a threaded bung in their pipes and use Air/Fuel meters to tune their bikes. Lol
Old 08-15-2015, 09:51 AM
Upyourkiltbatman's Avatar
Upyourkiltbatman Upyourkiltbatman is offline
I've tried loads of different setups on my 2011 300 , and stuck with ne3w clip 2 40 p. 180 main the bike is fast and aggressive with a nice plug colour only thing is i don't need choke to start from cold , second kick , don't know if this is a problem as it runs and idles good ?
Just need to test it love , only be a hour
Old 08-15-2015, 08:36 PM
I don't have to use the choke in the summer either. Bike will sit and idle all day long. I have the same jetting except I use the N3CH clip 3
Old 08-16-2015, 03:13 PM
krazy's Avatar
Default Crank seal??
Just an update, I've got the n3ew installed, and after lots of clearing out it runs pretty good. But something wasn't quite right. Then I noticed I am losing some gearbox oil. I'm pretty sure that is what's happening anyway, possibly right side crank seal from what I can gather. Clutch cover is also weeping a bit. Probably why I have been chasing my tail. Never been into a 2T engine before so going to research that next. Sigh.....
need to lean out bottem end gassergrant Enduro Intake/Carburetion - 2 stroke 3 08-24-2014 02:49 PM
Lean Surge??? Zman Enduro Intake/Carburetion - 2 stroke 13 05-23-2014 07:58 PM
Lean on top 300 2010 kiwia Enduro Intake/Carburetion - 2 stroke 9 11-26-2012 03:59 AM
Is this a bit lean or ok Simmo737 Enduro Intake/Carburetion - 2 stroke 7 09-11-2011 05:02 AM
WOT stumble DaveJ Enduro Intake/Carburetion - 2 stroke 21 04-18-2007 05:41 AM
