ignition side thread ec 200
hello, quick question,
i'm about to make a FWW on the lathe this weekend, and i have the drawings. Is the thread on the ignition side the same for all (2T)gassers : 12x1.25mm RH thread? thanks, Hannes. |
Yes - I wouldn't have known the measurements but I've used the same flywheel puller on 125,200,250,300s I've owned over the years.
Old GGs: 01 XC300, 02 XC125, 03 DE300, 03 DEO200, 01 SE300, 2011 EC300 Current: 05 DE250, Showa forked frankenbike 300, 05 DE300, 19 YZ250X |
Sent from my GT-I9505 using Tapatalk
it's regarding the thread on the cranck, sorry , i wasn't very clear on that part of the question :-)
Hannes. so no one is shure of this? Hannes. Last edited by hannesd; 01-31-2014 at 06:47 AM. |
Ignition side crank bearing failure? | wence | Enduro Engine - 2 stroke | 37 | 06-16-2016 07:21 PM |
ignition side breather / drain - ideas ? | Caravan Monster | Enduro Engine - 2 stroke | 11 | 07-16-2012 10:33 PM |
My Go Pro HD Thread | SideshowBob | Pictures & Videos | 18 | 04-25-2011 03:07 PM |
thread | jriley43 | General Discussions & Announcements | 15 | 03-17-2010 03:51 PM |
04 300EC Ignition changed to DE Ignition | Trail Blazer | Enduro Engine - 2 stroke | 0 | 01-08-2007 01:48 AM |
