WP 43mm revalve options
Hi does anybody have any experience with Fab-tech revalve kits, or know of any other options availible for the WP 43mm forks the seem to beat me to death on brake stutter bumps and chop?
Thanks in advance |
Send them to Enduro Engineering in Michigan and your problems will be solved.
A base valve kit or a "shim kit" won't resolve the harsh action that you are experiencing with the 43mm WP and the original base valves are fine. The cartridge needs "more" to "fix it".
I would recommend that you go to LT-Racing for this work - or at least call him to get his advice. He is very reasonably priced and doesn't charge any extra for the additional work required to resolve the issues with this fork. www.lt-racing.com Jeff
thanks for the replies but I am not in the USA I am in New Zealand, a long way from LTR. Any other ideas will be apreciated.
Have you contacted Ritchie at MotoSR 021 514 775, 07 308 0310 motosr@gmail.com
Or Norm Cobb at suspension tech normcobb@suspensiontech.com Or Linton at Dirt action services http://dasmoto.co.nz/?page_id=13 Linton is a GG guy from way back, I would call him first and see if he can help and if not try the other 2. |
Thank will give him a call
2010 Ohlins shock - rebound & revalve | Keg | Enduro Suspension | 1 | 04-10-2010 04:43 PM |
New Spring or Revalve | bigfoot_zn | Enduro Suspension | 1 | 06-29-2009 06:54 AM |
43mm WP rebound, help! | rupecopp | Enduro Suspension | 2 | 01-03-2009 11:01 PM |
LTR Suspension Revalve on '07 EC250 | GMP | Ride Reports | 0 | 06-17-2007 07:36 PM |
Removing cartridges from 43mm WPs | SpeedyManiac | Enduro Suspension | 8 | 05-29-2007 06:33 AM |
