2011 EC 300 rear wheel
Does anyone know if a rear wheel from a KTM... Yamaha ... Honda... ETC... cross-over to fit a 2011 EC300? I know other parts from other brands cross over , would like to know if a whole wheel assembly would work with maybe just changing spacers. Thanks
No, why?!? I guess with correct spacers you can make anything kinda fit. There are tons of used GasGas wheels out there, and they nearly all cross.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
Don't know if the earlier wheels(pre-07) fit the later chassis. If so, my '00 XC had a 19" MX wheel from a '95 KX 250. It slid right in with the KX spacers, but ultimately wasn't precise enough for me. I know I made shims, but never wrote anything down. When I sold the bike(after a bad crash) I kept the KX wheel, since was part of a set. I do know, on a scale of 1-10, the difficulty level was a 2. It took about an hour to get rideable.
All healed up, and ready to burn some fat. |
I have not found used wheels .... where can I look ??? Thanks
2003-11 are the same.
Fire1998 had a part out $100 each for Did u shaped rims, maybe he still has them? If I needed them I would buy both front and rear. Dang he sold them already.... But keep eyes open for part outs.
OK, I'll keep looking...Thanks
wheel
I've put the rear wheel off of my 1985 KDX 250 on . If you grind the one spool slightly it is a pretty good fit . So KDX 200 may be the same and maybe KX 250 possibly . Punk
2011 EC300 rear wheel | Gasaholic | Parts | 0 | 09-04-2014 09:21 PM |
2011 rear wheel bearings | fasteddy | Enduro Chassis & Body | 5 | 08-10-2013 06:28 AM |
2011 Rear Hub/Wheel & spoke | BrentMartell | Enduro Chassis & Body | 12 | 06-20-2012 01:41 PM |
