Ohlins Shock Spring
Looking for a .48 (OEM) spring for my 99 EC 200.
Thanks
i've got a 4.8 spring from house of horsepower.......
2011 GasGas ec300R 2011 GasGas ec200 Six Days |
Not sure if the newer Ohlins springs fit the older shocks?
I will measure the id of my current spring. Thanks
spring
is the 4.8 the standard ?
If so i/m sure I have one Stoby |
I've got 4.6 & 4.8 OE Ohlins springs I'd sell. They are in almost like new condition.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 Last edited by nknudsen; 11-25-2013 at 09:55 AM. |
Standard is usually 5.2 but check the part #. Maybe the the late 90's early 00's is different?
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
The 125 and 200 had a lighter spring than the 250/300. I believe it was 5.0 as OEM rate for the smaller bikes.
Sent from my GT-I9505 using Tapatalk
Noah, got your PM.....thanks.... I will let you know.
Thanks Working on getting OEM info...this is not a dead thread yet...Thanks
Ohlins 4.6 shock spring | nknudsen | Parts | 10 | 02-18-2015 01:57 PM |
ohlins shock spring # 60 | motomickey | Parts | 0 | 03-31-2013 10:33 PM |
Shock Spring for Ohlins 888 | Jakobi | Enduro Suspension | 1 | 02-23-2012 12:04 PM |
