Bad bottom end possible electrical fault
Hi guys,
I?m trying to sort a poor bottom end on my 2015 ec250 and something has just dawned on me. About 5 rides ago, I did away with the estart and fitted the plastic cover. I undid the three longish cap head screws that went through the starter ring gear, through the spacer and then through the flywheel and pulled the ring gear and the spacer off. I did not put the three bolts back in as at the time and still now i am unable to see if they had any other purpose looking at the drawings. Is there anyway the timing could now be out due to not refitting the three bolts, I?m not very au fait with what?s behind the flywheel so don?t know whether or not I could?ve caused a timing issue which has in turn caused the now power issue I?m having. |
2006 EC200 ignition fault diagnosis | Caravan Monster | Enduro Electrical & Wiring | 13 | 04-26-2016 03:17 PM |
A lot of fault spark plugs... | dimtsam | Enduro Intake/Carburetion - 2 stroke | 6 | 11-14-2014 09:51 AM |
Few electrical questions | Pinittowinit | Enduro Electrical & Wiring | 2 | 11-06-2013 06:34 PM |
really need help with my electrical | bronco-hunter | Enduro Electrical & Wiring | 17 | 01-07-2009 08:37 AM |
Fuel tap fault | Warwick Simpson | Enduro Intake/Carburetion - 2 stroke | 0 | 11-09-2008 12:15 AM |
