Old 05-12-2021, 02:48 PM
gasser's Avatar
gasser gasser is offline
Default NEED Help with starter
2018ec300 starter worked perfectly till about 75 hours and was still working perfectly until it hung engaged and burned up the relay/solenoid. I've put on a new starter motor, solenoid, and starter button. I can jumper across the solenoid and the starter turns fine but not even a click when I try a start with the button. That only leaves the diode module and the wiring. How do I check the diode and where can I get one?
Old 05-12-2021, 04:28 PM
The small red wire at the starter solenoid provides the 12v from the start button.
I would check that circuit next.
e-starter kit! Frie82 "Wanted to Buy" & "Want To Trade" 0 08-29-2017 02:03 PM
15 starter set-up pigpen966 Enduro Electrical & Wiring 5 10-02-2016 05:48 PM
Can I add a starter? Jeffm Enduro Electrical & Wiring 17 11-09-2013 07:23 PM
starter jet....where and how? mp5 Enduro Intake/Carburetion - 2 stroke 1 05-01-2013 09:13 AM
starter on 450 ec jenkitchen1006 Enduro Engine 4 stroke (including EFI & Exhaust) 3 05-21-2009 06:38 AM
