#11
I am having a booging issue with the new setup. Bogs in 1st gear and then pics up. Also if it idles, when hot it tends to stall. needle is on 2nd clip. 175 main and 42 pilot. Idle screw is all the way in. air screw 1. 3/4 turn out. Not sure what to look for now. i think the float is set correct, but im no expert.
Not sure if fixed. I adjusted the throttle slide by adjusting the nut on top of the carb. So far idles better and no blurb when applying throttle. I will see how it goes once the motor is hot. Last edited by kyton; 09-21-2014 at 08:06 AM. |
Apt smart carb settings database, please post your settings | IDAHOSPUD | Enduro Intake/Carburetion - 2 stroke | 8 | 12-13-2013 04:45 AM |
Settings .... | Packman | Enduro Suspension | 2 | 05-14-2013 02:02 AM |
carb settings | chinesegav | United Kingdom | 2 | 01-13-2013 05:44 AM |
Settings | wmcpb04 | Enduro Suspension | 0 | 12-27-2012 04:08 PM |
carb settings? | youngy1984 | Enduro Intake/Carburetion - 2 stroke | 1 | 09-12-2011 10:24 AM |
