Old 03-18-2021, 08:58 AM
Demi Demi is offline
Default check engine light 2018 EC300 dash computer
I noticed the iight being on during as brief start, no clue and I did try a search, came up empty. Started first kick and seemed to run well. Thanks for any and all help.
Old 03-18-2021, 05:01 PM
Near certain that it does a check on start up. Shows and then clears. If it stays on it'll mean you have a code logged. Need to use a scanner with appropriate connection to find codes.
Old 03-18-2021, 09:53 PM
Thanks, it may have been there before, not sure. Will figure it out once it the bike is at temperature, etc. Thought it could even be that...? Seems to run fine for the minute or so o started it.
Old 03-19-2021, 10:01 AM
blitz11's Avatar
blitz11 blitz11 is offline
Smile
Gas cap not fully tightened?
Old 03-19-2021, 04:14 PM
Hopefully it isn't that, then again a simple explanation may be the best! I will give it a look, thanks!
Old 03-19-2021, 10:23 PM
Just to follow up, tried 2 other CDIs and the light does not come on at all... the CDI that throws the light has no running issues at all.
Old 03-20-2021, 12:41 AM
Gasser Nate's Avatar
As Jake said it is supposed to come on when you first start the bike and go out soon after. If in doubt read the manual! ��
Old 03-20-2021, 02:07 AM
I didn't see it anywhere in the manual or I wouldn't have bothered making a post. Reading a PDF is a PITA at times. I never saw the light with the OEM or Ignitech CDI, only the JD box and it stays on.
Always 0 MPH on the enduro computer (2018 EC300) CDBiker220 Enduro Electrical & Wiring 8 07-31-2019 07:28 AM
2006 EC300 Dash Wiring iflybyu Enduro Electrical & Wiring 6 08-18-2017 05:41 AM
Check electrics without engine running? DaveJ Enduro Electrical & Wiring 2 04-08-2017 07:43 PM
Dash computer for 14 300? markwoodlief "Wanted to Buy" & "Want To Trade" 1 04-11-2016 03:26 PM
gg rear brake light/enduro computer/headlight jt633 Parts 3 03-10-2013 10:27 AM
