Is 202psi normal?
Did a compression test on my 07 200, its done about 100 hours in total, and 80 on the top end (dont ask about that)
I was wondering if +200 psi is ok? Iv done the test about 8 times now, and every time its the same, and im using a good guage, which measures dads KTM as ~168psi and my 125 as ~178psi. Im not doing a wet compression test, where oil is put down the plug hole. It just seems like a ridiculously high compression? Thanks |
Thats good.Just be sure to use good quality high octane fuel.
My '08 ec 250 measures at 191psi. I'd say it's probably right.
Mike Sheetz OMRA #21AA What will I be riding next? Christini GG 300? '15 KTM 300 XC-W '08 EC 250 (Gone to new happy owner) Gran Prix Cycle LTR Suspension RB-Designs |
What base gaskets did you use on the rebuild? A reduction in thickness here will raise compression....
Barry 07 EC250 |
Barry, still running 2 base gaskets, the thin brown one and the green? one.
Starts easy, every time, runs well, was just curious really. |
Jetting Q: outside of the normal range. | slocalspode | Enduro Intake/Carburetion - 2 stroke | 8 | 05-17-2010 09:08 PM |
Normal 08' 250? | nick790 | Enduro Intake/Carburetion - 2 stroke | 6 | 03-25-2009 04:02 PM |
