oil leaking from air box
hi
I have a 2005 450cc FSE that I just bought. After the first ride I noticed some drops of engine oil leaking from the bottom of the air box housing (the black box in front of where the air filter is) First I thought it might be because of too much oil so I replaced the oil according to spec. (taking care to empty also the oil in the frame) But is still leaking. Any ideas? I was thinking engine breathing problems but I dont have a clue how to check that. Thanks in advance. |
That is a common problem with the 450's. I believe that the breather filter has to be in place and in place correctly to function. I wish I knew more about 4t bikes...
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
could the air filter have been over oiled?
Jack - western PA 2006 KTM 250 sx 2006 EC 200/ 11' style kit--GONE 2004 200 EXC 1997 KDX 220 2004 CRF 250X 1974 CL125 www.youtube.com/allthatstuff35 <---some gasgas videos here |
The 2005 is a notorious driveler. The breather hose needs to be split and retrofitted with multiple foam inserts. There was a factory kit for this including all the necessary items.
cheers Ragnar |
Just stuff the hose with very open foam.
The bike then obviously will draw unfiltered air so that can not be good. This will also show a leak for any drop of oil that is drawn through the breathere. I will therefore start by pluging that hole and see if that fixes things. My guess it that the former owner made that hole because oil was flowing out through the airl filter and he thought this was a fix for that!!!!! |
ouch, bad fix.
hi no this is engine olil.
Tags |
airbox, leak, oil |
Airbox leaking ...?? 07 FSR need help | Why Z? | Enduro Chassis & Body | 4 | 06-11-2014 09:15 PM |
forks leaking oil | Barton | Enduro Suspension | 4 | 01-19-2014 04:29 AM |
Leaking Oil not sure where from, see video ? | wakeymatt | Enduro Engine 4 stroke (including EFI & Exhaust) | 8 | 04-16-2013 05:34 PM |
leaking gascap | BryanMcc | Enduro Chassis & Body | 0 | 03-24-2013 09:19 PM |
Leaking gas cap. | Mick | Enduro Chassis & Body | 24 | 04-03-2012 01:22 PM |
