#11
I'm with Trev. The 09/10 headlight and fender tickles my fancy most. When I get to fitting the 2011 plastics I think I'll be leaving these parts off.
#12
Are the later ones THAT bad.....Or are the earlier ones just a little more eye-pleasing ?
If i post a picture up, can someone else with a later model do the same ? Its all new to me......
Regards Shuv - 2006 EC 250 |
#13
Just google different years and you'll get the idea. 07 was a bit chunky and agricultural looking. Then they were like yours through till 2010, then went to the more ktm style light.
#14
(It was to get a discussion going really !). Never mind.............
#15
http://www.ebay.co.uk/itm/stage6-Kei...-/400591612142 - set of pilot jets http://www.psntuning.co.uk/scooter_p...hp?prt_id=1637 - set of main jets (check, you might want a set lower than this!!) If you have a look of spooge, it is ALWAYS down to rich jetting, low compression or right hand crank seal. As mentioned, I am running 32:1 with no spooge whatsoever, personally I would just try putting in 32:1 for a start, this will lean your jetting out slightly, it may ride better or worse (if it is still rich then you will have a surplus of oil, the bike will load up). How well does the bike idle?
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#16
I had a play with jetting on my XR400 (successfully i might add) !, just about got there on my WR250F, and also sorted a TPS problem on my KTM 500. But 2 strokes is all new to me right now....... Im trying to get my head round 32:1 being a leaner mixture than 50:1 ! So your saying the mixture with more oil in it, is leaner as it has a lower percentage of fuel in it and therefore burns hotter ? Bike wasnt very that easy to set-up to idle - I did read-up something about the pilot jet is too small (?) as standard, and the air mixture screw is almost all the way in, but actually idling wise now its pretty clean and strong. Never stalls and doesnt hang and the choke works fine...
#17
More oil means thicker fuel, and that equals leaner jetting. Less fuel can make its way through the jets.
2013 GasGas 300 2004 GasGas 200 2011 GasGas 300 Ortonville Minnesota |
#18
Thankyou. Does that mean an offset of running say 36:1 compared to 50:1 would be better MPG ? All the info i can find says fuel tank capacity on a 2006 EC 250 is 9.5 litres. As my tank is completely full right now (I mix up 10 litres at a time with 200ml of oil) this means theres approx 190ml of oil in there @ 50:1 ratio. Few quick calculations show: 50:1 = 190ml of oil for 9.5 litrres 36:1 = 263ml of oil for 9.5 litres 32:1 = 296ml of oil for 9.5 litres Wonder if i should remove 73ml of fuel and then add 73ml of oil to get that tank to pretty much 36:1 ration to see how that runs, and see if i get less spooge, and if its a little 'crisper'..........
#19
I just do mine at the pump, if I put in 2549ml then 2549/32 = 79.65 or 80ml.
Personally I doubt changing the premix ratio that little will do much, you are talking about a 1% ish change, you can't buy jets that are 1% different to eachother (there is always an argument that changing premix changes your jetting, but if you do the math, it's crap). Answer these questions and I should be able to help you out. (the more information the better) How well does the bike idle? How does the bike ride up to mid throttle? If you hold the throttle still at mid throttle, does the bike lurch and sputter a little from the exhaust? At full throttle, does the bike rev to the moon or appear to lose power before it feels like it should? When warm, does the bike smoke at idle, full throttle and anywhere in between? When you decelerate do the revs 'hang'? (take a long time to drop) After a nice long run, does the bike's idle drop significantly compared to cold? And if you do know them What pilot jet? What air screw setting? (turns out from stop) What needle and what clip? (clip from top, top=1 bottom = 5) What main jet? You've said the idle screw is almost all the way in, that denotes lean idle, thus adding more oil will make it worse. You can pull the choke slightly when the bike is warm to see if it helps the idle, this will 100% confirm lean idle. That being said, if you are getting excess spooge, then perhaps the needle has been raised to compensate for a weak bottom end? And yes, your statement "Im trying to get my head round 32:1 being a leaner mixture than 50:1 ! So your saying the mixture with more oil in it, is leaner as it has a lower percentage of fuel in it and therefore burns hotter ?" is 100% correct, the difference to viscosity is negligible.
#20
I love your rear light, don't suppose you know where it is from?
LOTS of smoke ? | ACR Tom | Enduro Engine - 2 stroke | 8 | 04-05-2013 01:34 PM |
quick pics of my ride | sammyboy | Pictures & Videos | 0 | 07-29-2010 05:20 PM |
Blue smoke | iancp5 | Enduro Engine 4 stroke (including EFI & Exhaust) | 4 | 05-25-2010 07:55 AM |
Ride report & a couple of pics | Jeffro820 | Pictures & Videos | 5 | 11-18-2009 01:19 PM |
Test ride a Gasser? I'm headin' to Houston | AZRickD | General Discussions & Announcements | 16 | 10-10-2007 12:46 PM |
