Old 03-02-2015, 10:24 AM
95jersey 95jersey is offline
Default 2014 prewired for speedometer?
My 2014 300 came prewired for a speedometer. The harness is just sitting there. So my question is do I just need to buy a computer? Is one of the rotor bolts magnetized? I guess I am looking for advice as to what I need to buy/install to get the speedo function working?
Also, what is the OEM model? Trail Tech Endurance II?
Old 03-02-2015, 11:22 AM
Rob1965 Rob1965 is offline
Default Trail Tech
I just installed an Endurance II on my 14 200 and have nothing but trouble. It worked for a ride or 2 then sent it back. The Manufacturer supposedly fixed it but after one ride it's not working at all. Going to go through this one more time, then trash it if I have any more problems. The sad thing is they have good reviews. I may have just bought a lemon. Best of luck to you.
Old 03-03-2015, 12:21 AM
Blakelpd5 Blakelpd5 is offline
Rob, how was the install? is it plug-n-play? Hope your next unit is flawless!!! I've had trail-tech units in the past and they've been solid units.. Thanks for chiming in.
Old 08-27-2015, 03:23 PM
Trying to revive this. Just picked up an endurance II and trying to figure out how to use the existing wiring.
Old 08-27-2015, 04:56 PM
gg3's Avatar
gg3 gg3 is offline
Hi ,
Installed a Trailtech Endurance2 on my 2014.Just plug n play.All the correct connections were behind the headlight & the magnet on the front disc was already in place.But as we all know, not all models in the same year are the same.My experience with earlier endurance models hasn't been good so hoping I get better life out of this one.
Old 08-28-2015, 01:01 AM
Biff's Avatar
Biff Biff is offline
OEM on my 2013 is unstable , and will go nuts and lose all info.
Now zip tie a Garmin quest to bar pad.
Gives speed,distance and time moving / stopped,
Biff
Old 08-28-2015, 02:04 AM
pigpen966 pigpen966 is offline
Are you guys powering them from the bike? I just use the internal battery. Been on there 2 years and so far no issues at all.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 08-28-2015, 08:33 AM
So I was able to find more information. Some bikes are pre-wired, some have the hole in the rotor for the sensor, some come with the sensor, but in general the wiring harness has the power adapted.
Upon closer inspection, mine is pre-wired and has the harness already to go, I just apparently need a bracket to mount the sensor to the hub.
Old 08-28-2015, 03:23 PM
shultzy shultzy is offline
If your bike came with a magnet installed on the rotor you should be able to just screw the speed sensing cable into the threaded hole in the bottom of the front brake caliper holder. Nice and neat.
My 2014 Factory Replica came with the pre-installed magnet. It has the simplified race wiring harness though with no pre made speedo hookup. I have just been using the internal battery and it has been great. I could splice into the running light wiring if I really wanted power from the bike.
2014 ec 300 es bukwheat New Bikes 11 09-12-2014 01:07 PM
2014 TM's adv rider All Other Bikes... 8 03-08-2014 01:28 AM
2014 4t BEEBOB Enduro Engine 4 stroke (including EFI & Exhaust) 17 11-23-2013 07:29 AM
2011 xc 300 odo/speedometer ? Muddy General Discussions & Announcements 48 07-22-2013 10:38 AM
