Old 05-31-2017, 11:36 AM
Rampart Rampart is offline
Default EC300 generator question
Can someone tell - how many volts and amperes makes ec300 generator?
Old 05-31-2017, 02:20 PM
Neil E. Neil E. is offline
2K3 = 70W maximum
Voltage depends on your regulator (or rectifier if estart), assume about 14V
Old 05-31-2017, 02:42 PM
http://www.gasgasrider.org/forum/showthread.php?t=164
here says near 85W, so with 14 wolts it's near 6A, and if 12 wolts - 7A. ok.
My fan is 12 wolt 3.8A - will it survive direct install?
Old 06-01-2017, 12:07 PM
http://www.gasgasrider.org/forum/sho...4&postcount=13
Direct install on an estart bike can run your battery down. Particularily important in slow bushwacking situations.
A kickstart only bike will need the rectifier (as previously recommended).
Old 06-01-2017, 02:35 PM
I don't have estart or a battery
Here i asking output characteristics of generator, so i will understand which rectifier i need.
Old 06-01-2017, 06:44 PM
pscook's Avatar
pscook pscook is offline
I'm not the best with electrical, but shouldn't you get the size of rectifier that the fan draws? It won't matter if it's too big as the fan won't draw any more than it needs to run, right?
Phil
(New bike pending...)
Old 06-02-2017, 11:58 AM
Use the rectifier that comes with the fan kit. That's all you need.
300 EC generator output. Barbs Enduro Electrical & Wiring 2 05-23-2015 10:34 PM
portable generator/inverter john r b Other Stuff... 8 01-26-2014 09:57 PM
Gas to Propane generator conversion GMP Other Stuff... 5 11-11-2012 06:24 PM
flywheel weights kokusan generator Caravan Monster All Other Bikes... 5 06-14-2010 11:21 PM
Spring Generator moto9 Enduro Suspension 0 03-10-2009 01:51 AM
