Old 05-16-2017, 02:50 PM
liamthom's Avatar
liamthom liamthom is offline
Default trail tech: speed sensor reed or hall effect?
I was wondering if anyone here knows if the trail tech speed sensor for gas gas is a hall effect if reed switch?
thanks
Old 05-16-2017, 09:30 PM
Reed switch.
Hall effect won't use a magnet.
Old 05-17-2017, 09:30 AM
liamthom's Avatar
Originally Posted by gasgasman View Post
Reed switch.
That was my guess, thanks
Old 05-17-2017, 01:43 PM
Neil E. Neil E. is offline
Hall effect sensors do use a magnet. Industrial air cylinders have a magnet attached to the piston that triggers a hall effect sensor to indicate end of stroke (hall effect = transistor).
Reed switches (mechanical device) have a finite life span; the little metal "reed" can only flex so many thousand times before it breaks off.
Test speed sensor cable? andper Enduro Electrical & Wiring 4 04-06-2017 04:13 AM
Trail Tech Striker sworks2009 Enduro Electrical & Wiring 8 11-16-2015 02:27 PM
Trail Tech temp sensor Buysomerice Enduro Electrical & Wiring 3 06-21-2015 12:07 PM
trail tech voyager rzide Enduro Electrical & Wiring 6 05-07-2014 08:54 PM
