Old 08-10-2017, 04:01 PM
Johnson79 Johnson79 is offline
Default Clutch oil
What kind of clutch oil have u guys been using? Only mineral?
Old 08-10-2017, 05:01 PM
Harry's Avatar
Harry Harry is offline
ATF type F
Old 08-10-2017, 06:25 PM
pscook's Avatar
pscook pscook is offline
In the clutch master cylinder, or in the gear case? If in the clutch master cylinder, you need to use what it tells you to use, as I believe there might be a year or two which used DOT 4 brake fluid.
But if gear case, I use a blend of ATF Type F and motor oil. 75% ATF/25% 10w30 in the winter, and 50/50 ATF/10w30 in the summer.
Phil
(New bike pending...)
Old 08-11-2017, 12:47 AM
Most ajp clutches are mineral oil (I have been using 2.5wt fork oil as a substitute without any issues) but there are other year's (I think 2012 was one of them) that had a different clutch so best to check the cap of your master reservoir
how to fix MOST clutch problems + cr250r clutch conversion. stainlesscycle Enduro Engine - 2 stroke 70 10-26-2020 04:06 AM
Hydraulic clutch actuator and clutch rod budryzer Enduro Engine - 2 stroke 6 07-25-2015 07:44 PM
Auto clutch Install, Rekluse or S3 Clutch Basket? Moto7man General Discussions & Announcements 49 11-24-2013 12:41 AM
Clutch lever doesnt release clutch as soon as motor starts cal_tony Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-19-2012 08:59 AM
