Old 07-13-2021, 08:52 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by ditezz View Post
As for running the motor without the battery can destroy your electronics through over voltage.The battery is ,as well as being a load it acts like a regulator
On my (2015) bike, there is no battery. There is a capacitor in place of the battery. I'm not sure if the electrics are the same as the 2018-> bikes, but mine is all DC just as the newer ones.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 07-13-2021, 09:25 AM
Anders's Avatar
Originally Posted by Gasser Nate View Post
Lithium batteries hate any sort of parasitic loss like those accessories.
+1
I have had a Durbahn LifePo4 battery for more than ten years. Used it as a starting battery for my Bimota in the summer while using it for a enduro/Gasgas helmet-light in the winter. I connect the lamp directly to the battery, no connection to the Gasgas circuit. Earlier, I used a home-brewed lamp with a 35WHID kit, but wanted something lighter.
The new lamp is a Lumonite, normally running off a Lumonite battery. Hence, I use a DC-DC converter built for that particular lamp. One day, I forgot to disconnect the battery from the converter after turning off and disconnecting the lamp from the power supply. A couple of weeks later I found it in the car, the battery completely discharged. The end of a perfectly good battery, due to a small current drawn even when not in use.
So then I need a new battery...
Anders
1986 Duc Mille S2
etc
Old 07-13-2021, 10:23 PM
ditezz ditezz is offline
Obviously you have your electric start disconnected.Yes you can remove the battery if you put a cap in its place ,but your starter won't work.If you didnt use the cap ,you would fry the electronics
Old 07-14-2021, 05:23 AM
Anders's Avatar
Yes, my EC200 is a kick-start only model. And was delivered that way. I have never felt the need for an electric starter on that bike, as I run a Rekluse clutch and rarely need to restart it (unless I crash heavily). It will even idle for quite a while laying down. I guess its thanks to the Lectron.
Anders
1986 Duc Mille S2
etc
Old 07-14-2021, 07:19 AM
The subject is about an electric start bike ,obviously a kick start bike only would not have a battery and different circuitry
Image resizer module? stabak Suggestion Box 3 09-04-2012 01:42 AM
Am I missing something ??? Stoby Pictures & Videos 18 06-21-2011 04:00 PM
Thermo Fan Module Woody01 Australia & New Zealand 1 02-25-2008 07:42 PM
Thermo Fan Module Woody01 Other GasGas Bikes/Quads 5 10-09-2007 03:12 PM
Thermo Fan Module Burnout Woody01 General Discussions & Announcements 0 06-27-2007 02:17 AM
