short bar risers.....
on my 2001 300, i would like to try to raise the forks in the tripple clamp a line or 2 to experiment... with the stock set up, 7/8 bars, and just the cap on the wp's showing, the top adjuster is almost touching the bars.. I was looking sunday, i dont see any risers under an inch.. Looks to me like you could throw a flat washer or 2 under the clamp and get some room to move them around.. I have seen some stock looking risers on other bikes that look taller than mine, I am pretty short and dont like tall bars at all..
i think somewhere aroun 3/8 would do me fine...Any thoughts ?
broken down over 60 slow rider.. |
The bikes come with two aluminum spacer washers, about 2-3 mm thick, stacked as risers. I'm guessing yours were removed. A few good flat shim washers will work fine as long as you don't run out of threads on the bolts.
thanks glenn... yes i have plenty of threads... was wondering why those were so close...
RoxSpeed bar risers | Trailrider | Enduro Chassis & Body | 4 | 08-05-2008 06:02 AM |
Boomhauers Short Lived HS | Boomhauer | Pictures & Videos | 0 | 10-30-2007 08:26 PM |
A short Introduction....Finally | lukachuki | General Discussions & Announcements | 3 | 08-28-2007 07:02 PM |
Problem with Scotts tower and bar risers | d2w | Enduro Chassis & Body | 8 | 07-25-2007 10:30 PM |
