Milky Tranny Fluid - my problem finally solved - may help someone
Had been suffering with the milky tranny fluid problem for almost twelve months. Always evidence of water ingress inside the RHS power valve chamber.
Had almost gone blind looking through threads on the subject & changed water pump seal three times, put in new water pump shaft, re routed breather hose to frame etc with no joy. Was resigned to changing oil after each ride and just got on with riding it. Took it for an annual MOT test and noticed during the test it had puked a bit of coolant out of the overflow pipe...it had never done this before...(neither had there ever been much evidence of the expansion tank being filled/emptied during a ride) Fitted new radiator cap...bloody hell...been perfect now for three very long, technical & wet rides. Assuming the system was over pressurising and pushing water past the water pump seal/splashing up through PV actuator rod hole. Cant understand why there was never much coolant evident in the expansion tank though. With the new cap the expansion tank is working as it should. If your at your wits end and tried everything else its worth a shot for what it costs to replace.
Dave H BMW R1150GS Moto Morini 1200 Corsaro BMW R1200S GasGas EC300 |
Good find mate, Thanks for posting.
Its amazing how often a faulty cooling system in a bike or car comes down to something as simple as a radiator cap. Thanks for sharing.
Good find..Thx for posting.
HuskyDude 10 EC300XC 08 TE510 07 TXT 280 77 TY175 |
Ha! I just searched under rad cap as I was forming that theory. Here's the proof I need that it is worth trying. Another impeller seal is on way now, but what the heck. Thanks mate.
Well played! You might want to upgrade your existing cap with one range higher as well. 2010s with expansion tank had 1.4 bar; 2011s with essentially the same rads and water pump has cap rated at 1.8 bar.
Hmm
I have also heard of a non-properly functioning system pulling tranny oil into the cooling system when the bike is cooling down.
I had tranny oil in my coolant but turned out to be a loose impeller bolt
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public |
Also the impeller seal needs the correct preload I am told. I'll do both for the weekend.
Been told to flush box with diesel of all things to absorb the water & even start it on the stand for a couple of min & reflush, then run a cheap oil for a ride & then back to decent stuff. |
Kerosene was a trick taught to me by my dad. In WWII, he was a fighter aircraft mechanic on Guam. After an engine rebuild done under less than ideal conditions, they'd fill the oil system (dry sump) with kerosene, run the engine for about a minute, then drain the kerosene, and then refill with motor oil. Flushed all of the nasties out. Apparently, made a difference in engine longevity (for the better).
yeah I had flushed with Kero, but not run it. Diesel apparently is good for mopping up the water.
I might pour some of the remainder down the sparkplug holes of my mate's still seized RD350 in my lockup & try kicking it in a couple of months. Supposed to be the biz for that if left, more so that penetrating oil which I've tried. |
How much tranny fluid in a 03 EC250? | BluegassXCR | Enduro Engine - 2 stroke | 6 | 07-07-2011 02:20 PM |
I wanted a street legal 2 stroke. How I solved the problem | Bobt250 | General Discussions & Announcements | 11 | 12-27-2010 02:50 PM |
milky tranny fluid | skid jackson | Enduro Engine - 2 stroke | 62 | 06-12-2010 06:54 PM |
Milky tranny fluid? | dank | Enduro Engine - 2 stroke | 10 | 04-15-2010 09:45 PM |
finally had a problem! | mountain thumper | General Discussions & Announcements | 1 | 04-11-2008 05:07 PM |
