Old 03-01-2016, 04:06 AM
stian stian is offline
Default Rear shock caluclation (FSE Ohlins > EC300)
Hi. local bloke sells an FSE450 rear shock, a Ohlins. Standard spring (from manual) says its a 4.0nm with 258mm at rest position.
Not sure of the standard spring-rate of a 2006 EC300 with Sachs rear shock, but I am guessing that its rated in the ballpark of a rider weight around 65-75kg.
My Sachs probably has never been at service, and I need a new spring that are around the cost of the used Ohlins - that are in a good shape.
With gear etc, i am around 95kg / 210lbs.
How do you calculate the spring-rate of a rear shock to the weight of the rider?
The bike is used on the street as a supermotard.
Old 03-21-2016, 10:46 PM
GGRider01 GGRider01 is offline
Stian, kind of late reply however filling all this info out on racetech's website should get you in the ballpark..
http://racetech.com/ChooseVehicle.aspx At the top of this page is a big yellow link that says "Calculate spring rates yadda yadda"
Old 04-26-2016, 04:41 AM
Use what's in my Sig. We weight the same. I've had mine revalved and it rides perfect. 2mm preload on the forks. Set for 110mm race sag on rear.
2016 RM-Z450
Ohlins 888 Rear Shock mcnut Parts 13 01-10-2016 07:38 AM
ISO a Ohlins rear shock 05 fse 450 Dirtnasty Parts 10 10-17-2015 12:03 AM
Ohlins rear shock GAKLX Enduro Suspension 0 10-07-2013 10:37 AM
Ohlins rear shock fabulous furry Enduro Suspension 8 10-31-2011 07:28 AM
07 ec250 will 05 ohlins rear shock fit gasgasandrew Enduro Suspension 1 01-22-2010 04:39 PM
