Hardparts fan kit
Mine arrived today and it seems nobody has seen one installed. I'm just curious where the thermostat should go. And the fan for that matter. I assume the fan goes on the right rad.
Hardparts fan kit
From what I remember all goes in the right side.
In would just google KTM or CRF fan kit and that will give you some good examples and photos. When I had my CRF250x. I lived by this guys website. Towards the bottom he talks about adding a fan and all info. http://www.rickramsey.net/CRF250Xbigbore.htm Sent from my iPhone using Tapatalk
2012 - XC 300 Racing Seattle, WA Last edited by StuJohnson; 05-15-2014 at 08:53 PM. |
How does the coolant flow?
It would flow vertically from the water pump
2012 - XC 300 Racing Seattle, WA |
Looks like the stock fan set-up on my gg 300 quad,fan is bigger though.
I would assume the thermostat goes just before the coolant enters the engine and fan goes on the right as the coolant exits
Is this specifically for the GG or is it a KTM (or other brand) kit? Do you have a link? I've been wanting to add a fan to my 300 so a "bolt on" kit would be sweet. I had modded a KTM fan to fit my old CRF450R that I had, but that required a bit of bracket fabrication and welding.
Thank you, now to see what I'd need to do to mount it on my '01!
I still have no idea why anyone would need it on a Gasser? I've put mine through some stuff, slow, tight, stuck, clutch slip, & Rekluse abuse and I've yet to overheat.....
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
Hardparts Carbon fiber frame and swingarm guards | blanc | General Discussions & Announcements | 3 | 01-15-2011 10:43 AM |
GG Hardparts rear disc guard! | blanc | General Discussions & Announcements | 0 | 12-14-2010 07:12 AM |
GasGas Hardparts Catalog | dcg141 | General Discussions & Announcements | 16 | 12-08-2010 11:13 AM |
