connecting rod side to side tolerances2011 ec300
I'm just in the process of freshening up the top end and it appears to me that the side to side room on the bottom of the connecting rod might be at getting a touch loose. I can't find a gas gas specific tolerance but on a cr 250 it says .4 to .8 mm and I'm at .95. Were these loose motors? or is it time to freshen up the bottom end. The up and down is at just under a thousand of an inch so it's still within speck but also getting close to the upper limit
Any body have a spec sheet for these online? |
GG specifies
STD: 0.80 mm Limit: 1.00 mm |
Thanks alot for that. If you don't mind, where did you find that info? For future reference.
06 EC300 number plate left side | Adam500 | "Wanted to Buy" & "Want To Trade" | 1 | 12-28-2015 12:17 PM |
2009 EC300 side filter covers mounting ? | jprizz | Enduro Chassis & Body | 1 | 06-28-2014 07:08 AM |
2003 EC300 Side Plastics in Black (free-ish) | leftovers | Parts | 1 | 11-17-2013 07:19 PM |
2001 xc250 connecting rod side clearance | 70455 | Enduro Engine - 2 stroke | 12 | 11-28-2012 08:35 PM |
2000 EC300 Side Stand | bonkeye | Enduro Chassis & Body | 3 | 08-03-2011 04:32 PM |
